Live Binding Global Changes
28 Dec 2018 07:05 #6942 by support
Replied by support on topic Live Binding Global Changes
There is an envisioned way to do this properly - with "aliases" in the endpoint descriptors. However this is not yet available, it's on waiting list for quite a time already, unfortunately.
The options at hand are not very nice.
If this is a one-time change during development, the customer is advised to simply used textual Find-and-replace (can be applied to the source file generated in background for the form with Live Binding).
In theory it might be possible to do it also programatically in runtime, but that would be against the design principle of the Live Binding (the proper solution would be with the aliases :-( ). I am therefore hesitant to provide that advise unless absolutely necessary. It will probably result in an ugly code, and I will have to sit down and actually do it, in order to be able to provide any guidance. Let me know if it needed nevertheless. I am leaving for 3 days now and my options will be limited, though.
27 Dec 2018 22:24 #6941 by gkalipershad
I have been working with a customer who is working on a project, which includes 50 controls with Live Bindings. He has a need to change the endpoint descriptor on all of them. I was asked if there was a way to do this globally on all 50 controls, rather than doing them individually.
If there is a property that he can set programmatically to override what is configured in the Live Binding Properties, could you please point us in the right direction? I was not able to find what I needed in the User's Guide, but I could have missed something.
GK
