Writing to variables
17 Dec 2018 19:26 #6925 by support
Replied by support on topic Writing to variables
Thank you for update. I am glad it works.
Would you mind sharing what the problem/solution was?
17 Dec 2018 16:35 #6924 by SolutionNow
Replied by SolutionNow on topic Writing to variables
Never mind! Apparently my colleagues were able to get everything running correctly today. Thanks for the assistance though.
17 Dec 2018 11:07 #6923 by SolutionNow
To the Write issue: The idea was that you try the Write (the same value, and to the same node) using UaExpert. have you done that, and what were the results?
I've finally talked with my colleague and he tells me that UaExpert is able to write to the machine.
Note that you can still work with UA methods in QuickOPC (call them).
We don't understand how we can call the CallMethod method because it requires the name of the node of the method, but because it doesn't appear in the QuickOPC window we don't know how to get the name of the nodes.
We have installed our same program which incorporates QuickOPC at a different client of ours and with this client we don't have any problem writing directly to the variable. Just to remind you, at the client we are having this problem, we are able to write the variable to the server but it never arrives to the machine.
13 Dec 2018 14:54 #6916 by support
Please ignore my previous post.
By further looking into the issue, I have discovered that the little magenta icon shown with all the nodes in UaExpert that do not show in UADataDialog means "method".
Those are therefore nodes for UA Methods, and it is intentional that UADataDialog does not show them, because the dialog is intended for "data", that is, things that have value to read/write/subscribe, and you cannot do that with methods.
13 Dec 2018 14:18 #6914 by support
Thank you. This (missing nodes in UADataDialog - probably UA properties) may be a problem on our side. I will have a look at it.
Which version of QuickOPC is this with?
12 Dec 2018 16:04 #6913 by SolutionNow
For the write issue, I'll have to answer you about whether or not UaExpert can write later as I need to speak with various people who are not available at the moment.
For the browsing issue, the list view doesn't show anything new:
12 Dec 2018 15:33 #6912 by support
the two problems appear unrelated to me.
To the browsing issue: It might be that just QuickOPC shows the nodes differently. Please do this:
- Click on "Technology data..." ndoe in the Tree view (left pane).
- Post here an image of how the UADataDialog looks at the moment - not just the Tree view, but also the List view (right pane).
12 Dec 2018 11:48 #6908 by SolutionNow
We're having some problems writing to variables on the machine. Here is the piece of code that isn't working correctly at the moment:
String sServer = null, sNodo = null, sValore = null; sServer = production_ResourceOPCNodeDataGridView.Rows[production_ResourceOPCNodeDataGridView.CurrentRow.Index].Cells[4].Value.ToString(); sNodo = production_ResourceOPCNodeDataGridView.Rows[production_ResourceOPCNodeDataGridView.CurrentRow.Index].Cells[5].Value.ToString(); sValore = production_ResourceOPCNodeDataGridView.Rows[production_ResourceOPCNodeDataGridView.CurrentRow.Index].Cells[7].Value.ToString(); easyUAClient1.WriteValue(sServer, sNodo, sValore); //easyUAClient1.CallMethod() ????? }
It seems to us we have two different problems, but it is possible these two problems have a single cause.
The first problem is that the WriteValue() method is writing the value to the node correctly on the server, but it is not writing the the variable on the machine.
For the second problem, as per a previous conversation we had we downloaded the program UAExpert. These are the nodes UAExpert found on the server:
and these are the nodes we currently see through the uaDataDialog:
What do we need to do see the methods UAExpert found that the uaDataDialog isn't finding?
