nuget in vs 2017 any cpu and .net 4.5 not visible
18 Sep 2018 06:56 #6671 by admin
If you have set it after installing the NuGet package, I do not think it's going to work.
You either need to start new project, set it to 4.5.2 or later, and then install the NuGet package, OR uninstall the NuGet package you already have, and then install it.
18 Sep 2018 06:16 #6670 by KAMIN
I have tried to set it to 4.5.2, stil not visible.
18 Sep 2018 06:02 #6669 by support
We currently require .NET Framework 4.5.2 or later - is your project set to that?
18 Sep 2018 05:52 #6668 by KAMIN
Hello
I am trying to use the nugets latest version in vs2017 with .net 4.5.
I get the notification installed, but the dlls seem not to be present in resources of a project. Is there some catch?
