Custom fields of events from OPC UA
31 Jul 2018 18:08 #6561 by support
Where are you seeing the error? In the Exception property of the EasyUAEventNotificationEventArgs in the event handler?
31 Jul 2018 17:51 #6560 by sergsedeln
Yes, if I don't define the UAAttributeFieldCollection it works well, it receives the base event fields, but once I add UAAttributeFieldCollection argument, it gives errors.
31 Jul 2018 17:46 #6559 by sergsedeln
Thanks! Checked it now.
Somehow I'm getting
~Bad_SessionClosed 0x80260000 The session was closed by the client.~
Error.
I will try now without the UAAttributeFieldCollection definition, it used to work like this before for base event data.
31 Jul 2018 17:13 #6558 by support
I suppose this is what you are looking for - the Select clauses: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ml#The%20Select%20clauses.html .
31 Jul 2018 16:13 #6555 by sergsedeln
Hello dear experts,
I am using EasyUAClient to subscribe for server events but it is missing a lot of custom data fields PCS7 sends in the event. See the screenshot attached.
How do I enable them to be received with the event on opcClient.SubscribeEvent(...) method?
I tried opcClient.Enable(...) method to enable ConditionType but I am getting exceptions. Notice that UAExpert client can enable them and receive plenty of custom data. Now my task is to do same grammatically but seems like I am stuck
I'd appreciate an expert advice here. Thanks!
