Monitoring server subscribes count
30 May 2018 06:00 #6379 by support
I am still not sure if I understand your question, but I will try. If I misunderstood, let me know.
In QuickOPC, you are making method calls to subscribe the individual monitored items. The OPC UA subscriptions are maintained for you automatically by the component.
All monitored items that use the same parameters share the same subscriptions. So, if, for example, you subscribe to all your items with sampling rate 1000 milliseconds, and also do not set other subscription parameters, there will be *one* subscription created for all of them by QuickOPC.
If you then subscribe to one or more monitored items with sampling rate 2000 milliseconds, they will go into a second subscription, and so on.
29 May 2018 17:44 #6377 by p-toth
So I mean if you want to monitoring one nodeid on the OPC server, you must subscribe it to the server for monitoring. In the DeviceExplore.Config.xml you can define "maxsubscriptioncount" on the server. Question how can check how many subscription is created/active?
29 May 2018 16:42 #6374 by support
I am sorry but I do not understand your request.
What is it that you want to achieve? Can you give an example?
29 May 2018 14:21 #6371 by p-toth
Dear All,
Can you tell me how can monitoring OPC server subscribes? How subscribe is aktive.
Thank you in advance.
Best Regards.
