Xmlserver and EasyDAClient.SharedInstance.SubscribeItem
15 May 2018 16:20 #6338 by goosvanbeek
Thank you, it works as expected now!
Goos van Beek.
15 May 2018 16:01 #6337 by support
You are right, I apologize. The example on www.opclabs.com is not correct and we will fix it. There needs to be an additional 'state' argument at the end, which you can use to distinguish the callbacks (can be null).
A complete functional example can look like this:
// This example shows how subscribe to changes of a single item in an OPC XML-DA server and display the value of the item // with each change, using a callback method specified using lambda expression. using System.Diagnostics; using OpcLabs.EasyOpc.DataAccess; using System; using System.Threading; namespace DocExamples { namespace _EasyDAClient { partial class SubscribeItem { public static void CallbackLambdaXml() { // Instantiate the client object var client = new EasyDAClient(); Console.WriteLine("Subscribing..."); // The callback is a lambda expression the displays the value client.SubscribeItem( "http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx", "Dynamic/Analog Types/Int", 1000, (sender, eventArgs) => { Debug.Assert(eventArgs != null); if (eventArgs.Exception != null) Console.WriteLine(eventArgs.Exception.ToString()); else { Debug.Assert(eventArgs.Vtq != null); Console.WriteLine(eventArgs.Vtq.ToString()); } }, state: null); Console.WriteLine("Processing item changed events for 10 seconds..."); Thread.Sleep(10 * 1000); Console.WriteLine("Unsubscribing..."); client.UnsubscribeAllItems(); Console.WriteLine("Waiting for 2 seconds..."); Thread.Sleep(2 * 1000); } } } }
The following user(s) said Thank You: goosvanbeek
15 May 2018 12:37 #6334 by goosvanbeek
Hello support,
The code you suggested unfortunately doesn't work at my side.
www.opclabs.com/products/quickopc/opc-specifications/opc-xml-da
// The callback is a lambda expression that displays the value EasyDAClient.SharedInstance.SubscribeItem( "http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx", "Dynamic/Analog Types/Int", 1000, (_, args) => Console.WriteLine(args.Vtq.Value));
Method 'SubscribeItem' has 5 parameter(s) but is invoked with 4 argument(s)
https://www.screencast.com/t/vX1gCILPv
Goos van Beek
15 May 2018 08:51 #6332 by goosvanbeek
Thanks for the clear explanation. I used the code from this page: www.opclabs.com/ and wasn't aware that it could be different for a xml server.
I will test this later today and I expect no problems with it anymore.
Goos van Beek
15 May 2018 05:51 #6330 by support
You are passing wrong arguments to SuscribeItem. You have an additional "" as the first argument; that needs to be removed.
Compare your code carefully with e.g. www.opclabs.com/products/quickopc/opc-specifications/opc-xml-da .
In addition, note that the callback code is simplified for the purpose of making the example short. Your actual code should check the Exception property before accessing Vtq. See:
opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...AttributeData%20property).html
and
opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...r%20UAAttributeData.Value.html
14 May 2018 19:35 #6329 by goosvanbeek
Thanks for your quick reply.
This is the stacktrace:
" bij SharedInstanceTest.Program.<>c.<Main>b__0_0(Object _, EasyDAItemChangedEventArgs eventArgs) in C:\\KUKA\\DEV\\SharedInstanceTest\\SharedInstanceTest\\Program.cs:regel 16\r\n bij OpcLabs.BaseLib.Widgets.NotifyingWidget.<>c__DisplayClass45_0`1.<CallbackAction>b__0()\r\n bij OpcLabs.BaseLib.Widgets.NotifyingWidget.SafeCallback(String name, Action action)"
See also the image links below (unfortunately in dutch)
https://www.screencast.com/t/NttWKjg4Ht
https://www.screencast.com/t/hi8cSzCtqeb
Goos.
14 May 2018 19:11 #6328 by support
SharedInstance is not related to the issue.
Is eventArgs.Exception null? If it is not, what is the exception it contains?
14 May 2018 18:47 #6327 by goosvanbeek
Hello support,
I'm trying use EasyDAClient.SharedInstance.SubscribeItem on a xml server. I can subscribe my items, but the vtq returns null. Am I doing something wrong or isn't it possible to use an shared instance subscrubtion with a (KUKA)xml server
Using SharedInstances with an local OPCDA server works fine.
EasyDAClient.SharedInstance.SubscribeItem( "", "http://172.31.1.145:8081/DA", "RobotMSG.messageinfo", 1000, (_, eventArgs)=>Console.WriteLine(eventArgs.Vtq.Value));
Goos van Beek
