connection to kepwareserver
09 May 2018 18:12 #6322 by support
There were two differences originally:
- The NodeId in your code was missing two pairs of doublequotes, and
- The NodeId in your code had an additional V_ at the beginning of the string identifier.
In your latest image, you have properly corrected the missing double quotes, but you still have the V_ in front of string identifier that is not present in the screenshot you provided from the other OPC UA client. You need to remove the V_ part.
09 May 2018 11:45 - 09 May 2018 11:45 #6320 by support
Yes.
And, I can see you use different NodeIDs in your code versus the screenshot from "OPC UA Client".
In your code, you have:
ns=3;s=V_FB_Holo_DB.IntCounter
In OPC UA Client, you use:
ns=3;s="FB_Holo_DB"."IntCounter"
You need to use the same NodeID in both tests, in order to be able to make a comparison that has relevance.
Last edit: 09 May 2018 11:45 by support.
09 May 2018 08:18 #6318 by support
Kepware OPC Quick Client uses OPC Classic to make the connection. Your code is using OPC UA. There is absolutely no conclusion you can draw for OPC UA from the fact that some tag can be read through OPC Classic.
You need to test with some other client that uses OPC UA.
08 May 2018 16:01 #6316 by support
Most likely the server is sending the data in this way - with no value. So the issue needs to be resolved at the server (or, you are looking at wrong data).
Have you tried some other OPC client to check the same data? This way you could determine whether there is something specific to QuickOPC behavior ot not.
04 May 2018 10:43 #6301 by support
what error message are you getting?
Check the server address. Are you sure it is on port 4840? KepServer has "OPC UA Configuration" manager which shows the URLS of the enabled endpoints .
