How to..?
23 Mar 2018 11:08 #6177 by support
Replied by support on topic How to..?
When you have created the Windows Forms application, you have used .NET: Either C#, or VB.NET.
When the documentation says "simply reference the Opclabs... assembly", it also has a V# or VB.NET project in mind, although for a console application.
But, in your post, your mentioned "VC++". C++ is different from C# or VB.NET. So first thing we need to establish, which language you actually want to use for your console app. My recommendation would be C# or VB.NET.
Please clarify, and I will give further instructions then.
23 Mar 2018 10:56 #6176 by netcloudengineering
Hello and congratulations for the fantastic product!
I was able to setup a small opc client in a couple of minutes using the windows forms and following the quick start document. However, I am having a hard time doing the same with a console application. The quick start document says: "simply reference the Opclabs... assembly". It is the first time I use VC++ and I have no idea how to do that "simple" task. Can you please provide more specific information? I searched the net but it looks like there are millions of different ways and none seems to work for me. I have VS2010, no .lib files, only the .dlls... how do I do that? I tried to open the consoleapplication1 that came with the package but VS2010 says it cannot be converted, there are a few errors in the logger. So I can't see what settings I need to add to my project in order to link the dll. I hope you can help me. Thank you!!!
Especialistas en telecomunicaciones y ciberseguridad industrial en Barcelona.
