Runtime licenses
08 Mar 2018 13:35 #6124 by dani.hartman@metronik.si
I saw these topics but I just needed to make sure that I won't have to buy additional licenses for computers where the code will be deployed.
Dani
08 Mar 2018 13:27 #6122 by dani.hartman@metronik.si
Thank you for a quick response.
So, if I understand it right - I need to install the same license on all computers where the code will be deployed?
08 Mar 2018 13:20 #6121 by support
Replied by support on topic Runtime licenses
first, a slight correction: You wrote
... Quick OPC Professional Single Developer + Runtime Free License and I can develop software only on one computer but deploy to any number of computers.
Actually, the developer (a person) can also develop on multiple computers. It's just that if you have two or more persons in a developer role, then they need more licenses or a different type of license.
It does not matter whether the code is compiled or interpreted. Creating or modifying VBA code is obviously a development, and not runtime. The license restrictions are not technically enforced in this respect, but it is your *legal* obligation to follow the license terms.
Yes, the QuickOPC license needs to be installed on any computer where QuickOPC runs - so if you will be using it from VBA, it will be needed on the computers where the VBA code runs. This again is actually independent of whether the code was compiled or interpreted: The license used on the development computer does not get embedded into the compiled programs either.
08 Mar 2018 12:41 #6120 by dani.hartman@metronik.si
As I understand your licensing policy, I only need to buy a Quick OPC Professional Single Developer + Runtime Free License and I can develop software only on one computer but deploy to any number of computers.
How does this work if I use OPC connections in VBA code, which is not compiled into a program and can be changed on any computer? And what does Runtime free license mean - do I have to install any licence on computers where my VBA code is deployed and is using OPC connection with your libraries?
Thank you in advance and best regards,
Danijel
