Attempt to add existing key into a dictionary
26 Feb 2018 20:34 #6076 by support
Although I was not able to reproduce the issue, I found that a synchronization statement is missing, and that it is a likely cause of the problem.
This is now fixed in the currently posted QuickOPC 2018.1 (on our Web page, and also in the NuGet packages). It is version/build 5.52.91 or later.
Please rebuild your project with it and re-test.
20 Feb 2018 17:04 #6065 by support
Thank you very much for the additional information. It is very helpful. From the call stack, it looks like a bug in QuickOPC. Unfortunately I cannot determine more details until next week when I am back in the office.
Please bear with me and I will respond then.
The following user(s) said Thank You: giles
20 Feb 2018 09:19 #6063 by giles
Hi I am now setting application name
this log shows call stack and log entries
Running a transacted installation. Beginning the Install phase of the installation. See the contents of the log file for the C:\XML Download\[DELETED INFO 1]\OpcToXml.exe assembly's progress. The file is located at C:\XML Download\[DELETED INFO 1]\OpcToXml.InstallLog. Installing assembly 'C:\XML Download\[DELETED INFO 1]\OpcToXml.exe'. Affected parameters are: logtoconsole = assemblypath = C:\XML Download\[DELETED INFO 1]\OpcToXml.exe logfile = C:\XML Download\[DELETED INFO 1]\OpcToXml.InstallLog Installing service OpcXml... Creating EventLog source OpcXml in log Application... Log entry: OPC-UA engine application info 'Time' -> UtcNow: 02/20/2018 08:58:48, Now: 02/20/2018 03:58:48, TickCount: 332722894. Log entry: OPC-UA engine application info 'Debugger' -> IsAttached: False. Log entry: OPC-UA engine application info 'AssemblyProperties' -> FullName: "Opc Labs.BaseLib, Version=5.52.66.2, Culture=neutral, PublicKeyToken=6faddca41dacb40 9", Location: "C:\XML Download\[DELETED INFO 1]\OpcLabs.BaseLib.dll", GlobalAssemblyCac he: False. Log entry: OPC-UA engine application info 'AssemblyAttributes' -> AssemblyConfig uration: "Release". Log entry: OPC-UA engine application info 'AppDomain' -> Id: 1. Log entry: OPC-UA engine application info 'Clr' -> Version: '4.0.30319.34209', P trSize: 8. Log entry: OPC-UA engine application info 'Process' -> Is64BitProcess: True, Cur rentDirectory: "C:\XML Download\[DELETED INFO 1]", Id: 1684. Log entry: OPC-UA engine application info 'User' -> Name: "richmar7", DomainName : "[DELETED INFO 2]", Interactive: True. Log entry: OPC-UA engine application info 'OSConfiguration' -> MachineName: "GBC RAPT10009", SystemPageSize: 4096. Log entry: OPC-UA engine application info 'OperatingSystem' -> VersionString: "M icrosoft Windows NT 6.1.7601 Service Pack 1". Log entry: OPC-UA engine application info 'Environment' -> Is64BitOperatingSyste m: True, SystemDirectory: "C:\windows\system32". Log entry: OPC-UA engine application info 'Computer' -> ProcessorCount: 2. Log entry: The OPC-UA engine is connecting to the underlying subsystems. Log entry: OPC-UA engine SDK configuration successfully provided by "OpcLabs.Eas yOpc.UA.Toolkit.InternalSdkConfigurationProvider". Log entry: OPC-UA engine SDK configuration successfully provided by "OpcLabs.Eas yOpc.UA.Toolkit.InternalSdkConfigurationProvider". Log entry: The OPC-UA engine has determined the client instance certificate para meters as listed below. SubjectName: OPC XML File Writer StorePath: %CommonApplicationData%\OPC Foundation\CertificateStores\MachineDefau lt ApplicationName: OPC XML File Writer ApplicationUri: urn:[DELETED INFO 3]:InstallUtil:4.0.0.0:neutral:b03f5f7f11d50a3a Log entry: The OPC-UA engine has determined the client instance certificate para meters as listed below. SubjectName: OPC XML File Writer StorePath: %CommonApplicationData%\OPC Foundation\CertificateStores\MachineDefau lt ApplicationName: OPC XML File Writer ApplicationUri: urn:[DELETED INFO 3]:InstallUtil:4.0.0.0:neutral:b03f5f7f11d50a3a Log entry: The OPC-UA engine will resolve the client instance certificate parame ters directory store path to "C:\ProgramData\OPC Foundation\CertificateStores\Ma chineDefault". Log entry: The OPC-UA engine will resolve the client instance certificate parame ters directory store path to "C:\ProgramData\OPC Foundation\CertificateStores\Ma chineDefault". Log entry: The OPC-UA engine has determined the application configuration parame ters as listed below. ProductUri: urn:literal:string:Microsoft%C2%AE%20.NET%20Framework Log entry: The OPC-UA engine has determined the application configuration parame ters as listed below. ProductUri: urn:literal:string:Microsoft%C2%AE%20.NET%20Framework Attempt to add existing key into a dictionary. at OpcLabs.BaseLib.Diagnostics.Always.Requires[TException](Boolean condition, String userMessage) at OpcLabs.BaseLib.Boxing.ManagedBoxedApp.SupportsFileVirtualizationForExecut ion(Int32 bitness) at OpcLabs.BaseLib.Boxing.Boxer.CreateBoxedFile(String virtualPath, Stream st ream, Int32 executionBitness) at OpcLabs.BaseLib.Boxing.Boxer.CreateFileFromManifestResource(IEnumerable`1 boxedFilePaths, Assembly assembly, String resourceName, Boolean weakBoxing, Int3 2 executionBitness, String& boxedFilePath) at OpcLabs.EasyOpc.UA.Boxing.Redistributables.UACertificateGeneratorBoxer.Box UABinary(String fileName, Boolean weakBoxing, Int32 executionBitness) at OpcLabs.EasyOpc.UA.Boxing.Redistributables.UACertificateGeneratorBoxer.Box () at OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.ValidateOrCreateClientCertif icate(ApplicationInstance sdkInstance) at OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.CreateSdkApplicationInstance (ApplicationInstance& sdkApplicationInstance) at OpcLabs.EasyOpc.UA.Implementations.NetSdk.NetSdkEasyUAClient.Install() at OpcToXml.ProjectInstaller.serviceInstaller1_AfterInstall(Object sender, In stallEventArgs e) in C:\OpcFileWriter\OpcToXml\ProjectInstaller.cs:line 30 An exception occurred in the OnAfterInstall event handler of System.ServiceProce ss.ServiceInstaller. System.ArgumentException: Attempt to add existing key into a dictionary. An exception occurred during the Install phase. System.InvalidOperationException: An exception occurred in the OnAfterInstall ev ent handler of System.ServiceProcess.ServiceInstaller. The inner exception System.ArgumentException was thrown with the following error message: Attempt to add existing key into a dictionary.. The Rollback phase of the installation is beginning. See the contents of the log file for the C:\XML Download\[DELETED INFO 1]\OpcToXml.exe assembly's progress. The file is located at C:\XML Download\[DELETED INFO 1]\OpcToXml.InstallLog. Rolling back assembly 'C:\XML Download\[DELETED INFO 1]\OpcToXml.exe'. Affected parameters are: logtoconsole = assemblypath = C:\XML Download\[DELETED INFO 1]\OpcToXml.exe logfile = C:\XML Download\[DELETED INFO 1]\OpcToXml.InstallLog Restoring event log to previous state for source OpcXml. The Rollback phase completed successfully. The transacted install has completed. The installation failed, and the rollback has been performed.
17 Feb 2018 15:03 #6059 by support
Thank you again. I do not know what is causing the problem, but below are some thoughts and hints.
1. The log you have sent contains two suspicious things: One is
An exception occurred in the OnAfterInstall event handler of System.ServiceProcess.ServiceInstaller.
System.ArgumentException: Attempt to add existing key into a dictionary."
The other is
OpcLabs.EasyOpc.UA.OperationModel.UAException: An OPC-UA operation failure with error code -1 (0xFFFFFFFF) occurred, originating from ''. The inner OPC-UA service exception with service result 'BadCertificateUntrusted' contains details about the problem.
The inner exception OpcLabs.EasyOpc.UA.UAServiceException was thrown with the following error message: Self Signed Certificate is not trusted.
IssuerName: CN=InstallUtil.exe, DC=[HIDDEN AS WELL] = BadCertificateUntrusted.
+ The error occurred while checking the (client) application instance certificate. The certificate generator path was "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Opc.Ua.CertificateGenerator.exe"..
Especially for the first one, it would be really useful to know the call stack (where it is coming from). Can you put try/catch block around the call to EasyUAClient.Install(), and log the call stack in case of an exception?
2. It would be also good if you can hook to EasyUAClient.LogEntry event before calling EasyUAClient.Install(), and then log all the message it generates.
3. Although what I will describe in this point is not probably causing the issue, it is a problem as well and I suggest that you resolve it. The problem has to do with naming of the generated certificate. If you do not set the name explicitly (more about it later), QuickOPC generates a name automatically, using information such as the running executable's name. The certificate name is used for lookup: When the certificate is generated, and the application is run the next time, it looks for the certificate and tries to reuse it.
In you case, using the automatically-generated certificate name will lead to problems. I can see that although your application's name is OpcToXml.exe, the name of the certificate generated by EasyUAClient.Install() is "InstallUtil.exe" - because that's what the running program at that time is, and "OpcToXml.exe" is just hosted by it. But when you will later run the actual OpcToXml.exe, it will look for "OpcToXml.exe" certificate (or possibly other auto-generated name - but not InstallUtil.exe".
In order to prevent this from happening, set the certificate (application) name explicitly in *both* the installation part, and the normal execution part, *before* calling EasyUAClient.Install() or any other of its methods. The process is described here: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Instance%20Certificate.html . An example in C# for that looks like this:
// This example demonstrates how to set the application name for the client certificate. using System; using OpcLabs.BaseLib.Instrumentation; using OpcLabs.EasyOpc.UA; namespace UADocExamples._UAApplicationParameters { class ApplicationName { public static void Main1() { // Hook static events EasyUAClient.LogEntry += EasyUAClientOnLogEntry; try { // Set the application name, which determins the subject of the client certificate. // Note that this only works once in each host process. EasyUAClient.SharedParameters.EngineParameters.ApplicationParameters.ApplicationName = "QuickOPC - CSharp example application"; // Do something - invoke an OPC read, to trigger some loggable entries. var client = new EasyUAClient(); client.ReadValue("http://opcua.demo-this.com:51211/UA/SampleServer", "nsu=http://test.org/UA/Data/;i=10853"); // The certificate will be located or created in a directory similar to: // C:\Users\All Users\OPC Foundation\CertificateStores\UA Applications\certs\ // and its subject will be as given by the application name. Console.WriteLine("Processing log entry events for 10 seconds..."); System.Threading.Thread.Sleep(10 * 1000); Console.WriteLine("Done."); } finally { // Unhook static events EasyUAClient.LogEntry -= EasyUAClientOnLogEntry; } } // Event handler for the LogEntry event. // Print the loggable entry containing client certificate parameters. private static void EasyUAClientOnLogEntry(object sender, LogEntryEventArgs logEntryEventArgs) { if (logEntryEventArgs.EventId == 161) Console.WriteLine(logEntryEventArgs); } } }
16 Feb 2018 15:26 #6055 by giles
1) Which QuickOPC version/build are you using?
It's the nuget package version 5.52.75
2) The certificate needs to be installed into the trusted store. Does your customer run the installer under administrator account, *and* with elevated privileges? (the behavior of Windows depends on UAC settings in this respect; your computer may be set differently than customer's).
They are 'running as administrator" - i assume this must mean they are an administrator...
On my PC the certificate ends up in c:\program data\OPC Foundation\CertificateStores\UA Applications\certs - i'll check what they have in there..
3) Is the installer in an executabel separate from the actual application, or are they "in one"?
They are installing the exe I have produced using installutil (in .net 4.5) folder
with...
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\InstallUtil.exe OpcToXml.exe
4) Do you set the ApplicationName parameter in EasyUAClient shared parameters either in the installer project, or in the actual app?
No
16 Feb 2018 15:15 #6054 by support
I do not know yet what can be causing it, but have some questtions:
16 Feb 2018 14:20 - 16 Feb 2018 15:15 #6053 by giles
Hi my client is trying to run the service installer I have written (which works in my system
this is what he gets in his event log (he has tried from two different directories) + [HIDDEN] and [HIDDEN AS WELL] is text i have replaced for anonimity
Installing assembly 'C:\XML Download\02 - Application Directory\OpcToXml.exe'.
logtoconsole =
assemblypath = C:\XML Download\02 - Application Directory\OpcToXml.exe
logfile = C:\XML Download\02 - Application Directory\OpcToXml.InstallLog
System.ArgumentException: An item with the same key has already been added.
Rolling back assembly 'C:\XML Download\02 - Application Directory\OpcToXml.exe'.
logtoconsole =
logtoconsole =
logtoconsole =
Installing assembly 'C:\XML Download\[HIDDEN]\OpcToXml.exe'.
logtoconsole =
assemblypath = C:\XML Download\[HIDDEN]\OpcToXml.exe
logfile = C:\XML Download\[HIDDEN]\OpcToXml.InstallLog
Rolling back assembly 'C:\XML Download\[HIDDEN]\OpcToXml.exe'.
logtoconsole =
logtoconsole =
logtoconsole =
my service installer just has:
```` using OpcLabs.EasyOpc.UA; using System; using System.Collections; using System.Collections.Generic; using System.ComponentModel; using System.Configuration.Install; using System.Linq; using System.Threading.Tasks; namespace OpcToXml { [RunInstaller(true)] public partial class ProjectInstaller : System.Configuration.Install.Installer { public ProjectInstaller() { InitializeComponent(); } private void serviceInstaller1_AfterInstall(object sender, InstallEventArgs e) { EasyUAClient.Install(); } } } ````
Last edit: 16 Feb 2018 15:15 by support.
