sdpdujc
31 Jan 2018 09:56 - 31 Jan 2018 09:56 #5928 by support
Replied by support on topic Get DataType ?
You can pass the attribute ID as a parameter to one of the ReadValue (extension) methods.
' This example shows how to read a value of a specific attribute of a single node, and display it. Imports OpcLabs.EasyOpc.UA Namespace UADocExamples._EasyUAClient Partial Friend Class ReadValue Public Shared Sub Overload2() ' Define which server and node we will work with. Dim endpointDescriptor As UAEndpointDescriptor = _ "http://opcua.demo-this.com:51211/UA/SampleServer" ' or "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer" Dim nodeDescriptor As UANodeDescriptor = "nsu=http://test.org/UA/Data/;i=10853" ' Instantiate the client object. Dim easyUAClient = New EasyUAClient() ' Obtain value of a DataType attribute. Dim value As Object = easyUAClient.ReadValue(endpointDescriptor, nodeDescriptor, UAAttributeId.DataType) ' Display results Console.WriteLine("value type: {0}", value.GetType()) Console.WriteLine("value: {0}", value) End Sub End Class End Namespace
Last edit: 31 Jan 2018 09:56 by support.
The following user(s) said Thank You: zarzar
31 Jan 2018 08:36 #5927 by zarzar
Get DataType ? was created by zarzar
how get DataType attribute for OPCUA NodeId in VB.NET?
Best regards, Robert
