Dynamic Tags - How to create them?
03 Jan 2018 13:36 #5797 by support
Something like this is fully done on the server side.
QuickOPC just passes the ItemIDs you specify in the code down to the server.
So, if you know the right syntax of the ItemID, you put that into your program, QuickOPC will pass it to the server, and the server will create the tag.
03 Jan 2018 13:30 #5796 by forum-dv
Hello!
Yes I am using QuickOPC .NET.
In my OPC server (Kepware) I create a list of tags (added channel and device first of course).
I can read tag values in my C# app.
Usually you can also create tag dynamically (using correct syntax), and OPC server will create
tags dynamically.
Is there a way to do that with QuickOPC client and Kepware v6
03 Jan 2018 12:56 #5795 by support
Unfortunately I do not understand your request.
Are you using QuickOPC as a client?
03 Jan 2018 10:45 #5791 by forum-dv
Hello!
Can you help me out?
I am trying to dynamically create tags for Siemens S7-300.
My OPC server is Kepware v6 (Siemens Suite)
For example: to read QB0
How do I do that?
