2nd SubscribeDataChange calls freeze
  • phil56
11 Jan 2018 07:37 #5851 by phil56
Replied by phil56 on topic 2nd SubscribeDataChange calls freeze
Thank you, it's good with this new version (5.52.0.4 ).
I restart my tests.
Regards.
09 Jan 2018 17:30 #5839 by support
Oh, you are absolutely right, I was able to reproduce the issue. Thank you for reporting it.
Can you please download a new build of 2018.2 preview version - from the same URL (it should report itself as 5.52.0.4 or later on the 1st page of the installation wizard), rebuild, and retest?
The following user(s) said Thank You: phil56
  • phil56
08 Jan 2018 09:37 #5821 by phil56
I did the test with a new console application (QuickOpc 5.52) and OPC Fondation UA Sample Server
Same problem
Sans indicateur 0 0 Thread inconnu [Thread détruit] Sans indicateur 4564 0 Thread de travail <Aucun nom> Normale Sans indicateur 12772 3 Thread de travail <Aucun nom> Normale Sans indicateur 5984 6 Thread de travail <Aucun nom> Normale Sans indicateur 19072 7 Thread de travail vshost.RunParkingWindow Microsoft.VisualStudio.HostingProcess.Utilities.dll!Microsoft.VisualStudio.HostingProcess.HostProc.WaitForThreadExit Normale [Code externe] Sans indicateur 13400 8 Thread de travail .NET SystemEvents System.dll!Microsoft.Win32.SystemEvents.WindowThreadProc Normale [Code externe] Sans indicateur > 13532 9 Thread principal Thread principal OpcLabs.BaseLib.dll!OpcLabs.BaseLib.Threading.MonitorLock.MonitorLock Normale [Code externe] TestPbOpcUA.exe!TestPbOpcUA.Program.Main(string[] args) Ligne 34 [Code externe] Sans indicateur 9312 12 Thread de travail Thread de travail OpcLabs.EasyOpcUA.dll!OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.TryGetConnectedEngineRecord Normale [Code externe] Sans indicateur 0 0 Thread inconnu [Thread détruit] Sans indicateur 0 0 Thread inconnu [Thread détruit] Sans indicateur 0 0 Thread inconnu [Thread détruit] Sans indicateur 10424 10 Thread de travail <Aucun nom> OpcLabs.BaseLib.dll!OpcLabs.BaseLib.Threading.PeriodicWorker.Process Normale [Code externe] Sans indicateur 20840 11 Thread de travail <Aucun nom> OpcLabs.EasyOpcUA.dll!OpcLabs.EasyOpc.UA.Toolkit.UASmartEngine.RemoveAndDisposeUnusedSessions Normale [Code externe]
Apparently main thread hang in OpcLabs.BaseLib.Threading.MonitorLock.MonitorLock !!
Regards.
vs project :
File Name: TestPbOpcUA.zip
File Size:4 KB
05 Jan 2018 07:54 #5810 by support
I suppose you have re-built your program after installation of new QuickOPC, right?
If so, I cannot tell more without actually going deeper into analyzing the hang. Can you please follow the steps described here?: kb.opclabs.com/Troubleshooting_program_hangs
  • phil56
04 Jan 2018 07:59 #5805 by phil56
unfortunately I have the same thing with this alpha version.
I did the test with different assembly versions, results :
QuickOpc 5.40 : OK
QuickOpc 5.50 : OK
QuickOpc 5.51 : KO
QuickOpc 5.52 (alpha) : KO
Regards.
03 Jan 2018 07:53 #5790 by support
The 2018.1 version is likely to be released in March 2018.
I will send you a link to an alpha version to the email you used to register with these forums.
  • phil56
02 Jan 2018 07:35 #5784 by phil56
yes I am interested by the alpha version.
A date for the 2018.1 version ?
01 Jan 2018 14:58 #5783 by support
This should not be happening, but we have seen it recently in other situation too. If it is the same thing, we have a fix already, but it will only be available to the public in the upcoming version (2018.1).
If you are interested, I can send you an alpha version for private testing. Let me know.
  • phil56
29 Dec 2017 07:34 #5778 by phil56
this is just a test case
private void Client_DataChangeNotification([JetBrains.Annotations.NotNull] object sender, [JetBrains.Annotations.NotNull] OpcLabs.EasyOpc.UA.OperationModel.EasyUADataChangeNotificationEventArgs e) { Console.WriteLine("Nouvelle valeur {0} : {1}", e.Arguments.NodeDescriptor.NodeId, e.AttributeData.Value); }
29 Dec 2017 07:03 #5777 by support
can you post the event handler code too?
Time to create page: 0.157 seconds
