C# Console Application Run As Windows Service Error on UA Client Connect
30 Nov 2017 15:19 #5702 by support
It is probably same as the issue described here: www.opclabs.com/forum/ua-com-connections-reconnections-certi...2257-opc-ua-using-php?start=20 , which is already fixed in the current QuickOPC version (2017.2).
There are also workarounds listed in the topics above.
30 Nov 2017 10:52 #5701 by Scattolaro
I solve the problem:
I try to use "nssm" application (ver. 2.24) to create my service from my console application with OPC UA Client.
If I use the nssm 64 bit version It's work properly. It doesn't throw the exception when I start the service.
30 Nov 2017 10:09 #5700 by Scattolaro
Sorry, the version of file "OpcLabs.EasyOpcUA.dll" is 5.35.442.1
30 Nov 2017 10:06 #5699 by support
I need version of one of the assemblies that start with OpcLabs.*.
30 Nov 2017 10:00 - 30 Nov 2017 10:01 #5698 by Scattolaro
The version of "Opc.Ua.Client.dll" file is 1.2.334.6
Last edit: 30 Nov 2017 10:01 by Scattolaro.
30 Nov 2017 09:56 #5697 by support
Which QuickOPC version and build are you using please?
30 Nov 2017 08:54 - 30 Nov 2017 08:59 #5696 by Scattolaro
When I run my console application as windows service the UA Client throws this exception:
Exception: System.ArgumentOutOfRangeException: La lunghezza non può essere minore di zero.Nome parametro: length in System.String.Substring(Int32 startIndex, Int32 length) in Opc.Ua.ApplicationConfiguration.GetFilePathFromAppConfig(String sectionName) in OpcLabs.EasyOpc.UA.Toolkit.AppConfigSdkConfigurationProvider.GetConfiguration(ApplicationInstance sdkApplicationInstance, ApplicationConfiguration& sdkApplicationConfiguration) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.MakeSdkApplicationConfiguration(ApplicationInstance sdkApplicationInstance, ApplicationConfiguration& sdkApplicationConfiguration) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.CreateSdkApplicationConfiguration(ApplicationInstance sdkApplicationInstance, ApplicationConfiguration& sdkApplicationConfiguration) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.CreateSdkApplicationInstance(ApplicationInstance& sdkApplicationInstance, ApplicationConfiguration& sdkApplicationConfiguration) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.MakeSdkApplicationInstance(ApplicationInstance& sdkApplicationInstance) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.InternalConnect() in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.Connect() in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.ExternalConnect() in OpcLabs.EasyOpc.UA.Engine.EasyUAEngine.BrowseNodes(UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, UABrowseParameters browseParameters, EasyUAAdaptableParameters adaptableParameters, Exception& exception, UANodeElementCollection& nodeElementCollection, List`1& warnings) in OpcLabs.EasyOpc.UA.EasyUAClient.InternalBrowseNodes(UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, UABrowseParameters browseParameters) in OpcLabs.EasyOpc.UA.EasyUAClient.<>c__DisplayClassb.<BrowseNodes>b__a() in OpcLabs.EasyOpc.UA.EasyUAClient.DisposeGuard[TResult](Func`1 func) in OpcLabs.EasyOpc.UA.EasyUAClient.DisposeGuardNotNull[TResult](Func`1 func) in OpcLabs.EasyOpc.UA.EasyUAClient.BrowseNodes(UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, UABrowseParameters browseParameters) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.BrowseDataNodes(IEasyUAClient easyUAClient, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.BrowseDataNodes(IEasyUAClient easyUAClient, UAEndpointDescriptor endpointDescriptor) in Qualitas.DeviceAppOPC.DataAccess.OPCserverCH.Open() in c:\Progetti\FDI_GIT\fdi\DeviceAppOPC\DataAccess\OPCserverCH.cs:riga 208(La lunghezza non può essere minore di zero.Nome parametro: length) Trace: in System.String.Substring(Int32 startIndex, Int32 length) in Opc.Ua.ApplicationConfiguration.GetFilePathFromAppConfig(String sectionName) in OpcLabs.EasyOpc.UA.Toolkit.AppConfigSdkConfigurationProvider.GetConfiguration(ApplicationInstance sdkApplicationInstance, ApplicationConfiguration& sdkApplicationConfiguration) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.MakeSdkApplicationConfiguration(ApplicationInstance sdkApplicationInstance, ApplicationConfiguration& sdkApplicationConfiguration) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.CreateSdkApplicationConfiguration(ApplicationInstance sdkApplicationInstance, ApplicationConfiguration& sdkApplicationConfiguration) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.CreateSdkApplicationInstance(ApplicationInstance& sdkApplicationInstance, ApplicationConfiguration& sdkApplicationConfiguration) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.MakeSdkApplicationInstance(ApplicationInstance& sdkApplicationInstance) in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.InternalConnect() in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.Connect() in OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.ExternalConnect() in OpcLabs.EasyOpc.UA.Engine.EasyUAEngine.BrowseNodes(UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, UABrowseParameters browseParameters, EasyUAAdaptableParameters adaptableParameters, Exception& exception, UANodeElementCollection& nodeElementCollection, List`1& warnings) in OpcLabs.EasyOpc.UA.EasyUAClient.InternalBrowseNodes(UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, UABrowseParameters browseParameters) in OpcLabs.EasyOpc.UA.EasyUAClient.<>c__DisplayClassb.<BrowseNodes>b__a() in OpcLabs.EasyOpc.UA.EasyUAClient.DisposeGuard[TResult](Func`1 func) in OpcLabs.EasyOpc.UA.EasyUAClient.DisposeGuardNotNull[TResult](Func`1 func) in OpcLabs.EasyOpc.UA.EasyUAClient.BrowseNodes(UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, UABrowseParameters browseParameters) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.BrowseDataNodes(IEasyUAClient easyUAClient, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.BrowseDataNodes(IEasyUAClient easyUAClient, UAEndpointDescriptor endpointDescriptor) in Qualitas.DeviceAppOPC.DataAccess.OPCserverCH.Open() in c:\Progetti\FDI_GIT\fdi\DeviceAppOPC\DataAccess\OPCserverCH.cs:riga 208;
Can you help me pleae?
Last edit: 30 Nov 2017 08:59 by Scattolaro.
