QuickOPC v5.50.334 easyDAClient getting Timestamp with Milliseconds rounded
06 Nov 2017 16:10 #5640 by support
QuickOPC passes the value from the server correctly, including milliseconds. I have verified that now. If you are displaying the value correctly, you need to ask this question the server vendor - why they are not sending out the milliseconds part.
BTW, getting dynamic OPC properties such as Timestamp should be avoided - it is fairly inefficient. You have OPC reads, and even better, subscriptions, if suitable, to obtain your data.
The following user(s) said Thank You: Roie.b
06 Nov 2017 15:26 #5639 by Roie.b
when reading value from QuickOPC DA(using GetMultiplePropertyValues function)
I am getting the Time Stamp of the value rounded to the last second, example: 2017-11-06 14:55:43.000
is there a way to get the time stamp with millisecond accuracy from the DA server?
I tried looking in the quickOPC guide but found nothing.
Best Regards,
Roie Beck
