"Object reference not set to an instance of an object" reading from remote OPC server
07 Oct 2017 09:19 #5576 by support
1. Please post your code.
2. Indicate on which statement the error occurs
3. Provide exception details, including the call stack.
06 Oct 2017 14:24 #5575 by SENTHILKUMAR
the example shared only for local host OPC server. it works well . but the same code is not working for remote machine. server descriptor is properly defined. but i am getting the error
we are able to read the read the server from remote. we are able to read the tag list from the remote. but we are not able to read the tag values.
i am facing the error attached
