How to activate the DLLs on target computer without using License Manager
20 Sep 2017 05:20 #5531 by Millon
Thnak you for your answer.
19 Sep 2017 15:50 #5527 by support
There is just one license. The same license is used for development and/or runtime purposes. So, it is the license we have shipped to you when you have purchased the product.
19 Sep 2017 15:33 #5526 by Millon
In the User's Guide there is:
Licensing
Application Deployment > Installation Elements > Licensing
Proper license (for runtime usage) must be installed on the target computer (the computer where the product will be running).....
Where is the runtime license ?
18 Sep 2017 11:07 #5518 by support
The information you are looking for is no longer in a separate document. Everything that you need is in the User's Guide ( opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ference-QuickOPC/webframe.html ), under the Application Deployment section.
The following user(s) said Thank You: Millon
18 Sep 2017 09:49 #5517 by Millon
I have just acquired a license of development and I have the same problem described in another topic (How to activate the DLLs on target computer without using License Manager?) to deploy my application on the client. May I obtain the document describing the method?
18 Sep 2017 09:40 #5516 by Millon
I have just acquired a license of development and I have the same problem described in another topic to deploy my application on the client. May I obtain the document describing the method?
