Reading multiple items from a remote server
21 Aug 2017 08:32 - 21 Aug 2017 08:32 #5443 by support
you need to use an appropriate overload of the ReadMultipleItems, for example:
[]).html
And you can construct the ServerDescriptor using a machine name and a ProgID: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ptor~_ctor(String,String).html
Let me know if you need further help with that.
Last edit: 21 Aug 2017 08:32 by support.
21 Aug 2017 08:25 #5442 by support
Sent: Friday, August 18, 2017 8:51 AM
To: Z.
Subject: RE: Reg Quick OPC Professional ...
Dear Z.,
we downloaded the trial version from your website.
we are facing trouble in reading multiple Tags from the remote machine.
can you suggest a procedure to read multiple tags from remote machine within a second.
we are using a function mentioned below:
DAVtqResult[] vtqResults = client.ReadMultipleItems(ServerClass, NodeItemDescriptor);
in the above function, we could not find a way to read he remote OPC server
please extend your help on the above.
with regards,
s.
