Impossible to connect client UA to TOP SERVER in same network
20 Aug 2017 13:04 #5441 by support
unfortunately I am unable to unpack the file you have attached. Please insert the files individually.
17 Aug 2017 20:34 #5440 by I-Tecnology
Good morning, I am trying to read an item on plc Siemens S7 with OPC Server TOP Server UA interface and client quick opc 2016.2 5.41 with anonymous client. On top server endpoint have security "none" and anonymous client are allow to be connected to server and able to read and write nodes. If client it's on the same pc where is installed Top Server node plc can be read. If client it's in different pc but connected in same local LAN witn OPC Top Server and PLC i receive always pop up with message "password network specified is not correct".
Firewall everywhere are disabled.
Best Regards
Time to create page: 0.149 seconds
