UA Browse Control Server Discovery Timeout
31 Jul 2017 10:17 #5392 by support
The timeout can be configured to a different value (it is in UADiscoveryParameters.DiscoveryTimeout, in milliseconds). Note, however, that lower timeout brings a risk that a discovery would time out even if it otherwise would be successful. We originally had 5 seconds as a default, but found it too short in practice.
There are currently no plans to allow the user code to cancel a discovery that it in progress ("externally"), if that is what you had in mind (and I am not sure where you have read that ?).
18 Jul 2017 15:32 #5372 by AdamBOD
I'm using the UA Browse Control but the timeout for the server discovery is too long, since the browse control launches on a secondary form, if I close it before the timeout it cause the main form to hang for 15 seconds.
I've read that this was a planned update but I couldn't find any documentation for it, just wondering if this is still planned?
