0x80040202 (CONNECT_E_CANNOTCONNECT ?)
14 Jul 2017 08:16 #5351 by support
Besides tweaking these settings (and possibly tweaking DCOM too), I cannot think of further options. The difference between other OPC client(s) and ours in this respect is usually in the fact that ours is .NET-based, and .NET host may do its own COM initialization which conflicts with what we want, for which all these extra settings exist.
CONNECT_E_CANNOTCONNECT is related to the "reverse" direction, when the server attempts to set up a callback to the client (for subscriptions). Sync reads/writes will probably work well.
13 Jul 2017 12:22 - 13 Jul 2017 12:25 #5350 by chrisbonnar
I tried all combinations.
UseCustomSecurity = false alone made no difference.
UseCustomSecurity = false + TurnOffActivitionSecurity = true resulted in a different error - "access denied". This may be a step forward? But I am still stuck.
This is a windows application, both debugging in Visual Studio and running the compiled exe is done under the identity of the current user - which is known to definitely have read/write access on the Kepware server. Running Visual Studio as administrator also made no difference.
Please advise.
Last edit: 13 Jul 2017 12:25 by chrisbonnar. Reason: added note about identities
13 Jul 2017 08:21 #5347 by support
can you please try different combinations of parameters as described here: www.opclabs.com/forum/connections-reconnections-com-dcom/124...ng-to-remote-machines-via-code .
12 Jul 2017 11:10 #5346 by chrisbonnar
Please see attached screenshot. I am trying to subscribe to a Kepware tag on a customer's remote server from my .NET windows application and I get a very unhelpful and non-descriptive error 0x80040202 in return.
On advice of an OPC Training Institute article I have run the OPC Expert utility on the same computer, and it can subscribe to the tag without issue.
Please advise.
