Value conversion and other [browse issues]
05 Apr 2017 13:16 #5077 by support
Sent: Wednesday, April 05, 2017 3:04 PM
To: Z.
Subject: RE: OPC Labs Contact Form - Value conversion and other
You ask what I can not see
For example I have an Hitachi PLC called PLC1
This I have made in my OPC DA Server
The PLC1 tag I can not find. Under that tag there are the PLC Tag adressen line M00000 or WM0000.
That PLC1 that is only available the first time I look for a tag.
After the first time it is nog shown and it gives an error.
I do not know hows fault it is Quick OPC or is it the Hitachi OPC DA Server.
The second or first quistion
It is about value conversion how van I do this. How can I validate and how can I convert.
I hope you understand me.
Greatings From W.
05 Apr 2017 12:48 #5075 by support
We will need more details to both issues in order to be able to tell more.
To the first issue:
1A) "I read an interger but it becames a string". QuickOPC does not do that, unless told to. How do you know that it has become a string?
1B) can you post your code here?
1C) "I can not write a value". What are the symptoms? Do you get an exception - if so, what is the exception text and details? Or is the write going through but it appears to be ignored?
To the second issue:
2A) "....I can not choose my PLC". I do not understand this quite well. Can you provide a picture, and explain what is the observed versus expected behavior?
2B) Do you get any error message in this case?
05 Apr 2017 12:44 #5074 by support
Sent: Wednesday, April 05, 2017 1:30 PM
To: Z.
Subject: OPC Labs Contact Form - Value conversion and other
I donw loaded your Quick OPC Client for Dot net.
But I can raed values but I can not write a value.
Do I need to fill in the conversion. I read an interger but it becames a string. Now I change a string and I want that it becomes an Integer.
Second I can choose mij points in myn Saia Burgess OPC DA server but I can only at the first time Browse in my OPC DA server from Hitachi and after the first time I can not choose my PLC
