(automatic installation of QuickOPC runtime)
30 Mar 2017 13:24 #5059 by support
A quote from opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Production%20installer.html :
The developer will find the link to download the production installer in the Redist directory
That is, you need to use the Full installer first (that should make sense because you need it to develop your product with, or at least rebuild).
30 Mar 2017 13:21 #5058 by support
Sent: Thursday, March 30, 2017 3:20 PM
To: Z.
Subject: AW: quickOPC
Dear Sir,
Thank you for the quick answer.
QuickOPC-2016.2-Production.exe seems to be the right package for us.
But at the moment I have only QuickOPC-5.35.exe
At your Homepage I found a Download of QuickOPC-2016.2-Full.exe.
I registered as User „Greiner-GEG“ but I could not find “QuickOPC-2016.2-Production.exe“ for download.
Can you tell me how to get it?
Freundliche Grüße
30 Mar 2017 12:07 - 30 Mar 2017 12:10 #5057 by support
Both your questions are addressed in the QuickOPC documentation. See the "Application Deployment" section.
In short, there is no .MSI. You can create your own installer using the information about the files and actions needed, as described in the Application Deployment section.
In the latest version (2016.2), you can also use a different approach. We have added a separate "Production" installer, for this purpose. It is an .EXE file again. See:
- kb.opclabs.com/What%E2%80%99s_New_in_QuickOPC_2016.2_(5.41)#Application_Deployment
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ference-QuickOPC/webframe.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Production%20installer.html
Do not forget to check the parts that describe license deployment, too.
I have quickly checked your license/purchase, and you have a maintenance period ending in December 2016, which should therefore cover the version 2016.2.
Our primary channel of support is through these forums, and in English (but you can type in your inputs in German, that would be fine). We do not normally provide any support over the phone.
Last edit: 30 Mar 2017 12:10 by support.
30 Mar 2017 11:59 #5056 by support
Sent: Thursday, March 30, 2017 1:51 PM
To: s.
Cc: Z.
Subject: quickOPC
Hello!
is it possible to get an setup.msi for automatic installation of quickOPC runtime.
We want to install quickOPC runtime on many PCs to get access to production process data.
2nd question: what modules are necessary if we use .net programming and COM?
How can we get Support (email or phone)? German or English?
phone: ...
Kind Regards
F.
