Opc Ua ExtensionObject
22 Dec 2016 14:56 - 22 Dec 2016 15:00 #4703 by support
Replied by support on topic Opc Ua ExtensionObject
Oh, I see.
There are 2 options (I haven't actually tried them, but the principles should work):
1) You need to "tell" the compiler that it is dealing with an ExtensionObject, by typecasting the received value to Opc.Ua.ExtensionObject, and then you will get the data from its Body property. In order to make the type cast, however, you will need to reference the Opc.Ua.Core assembly, and here is where the necessity to select the installation of Embedded Assemblies comes to play. And, as a third execution step, you will need to type cast the value from Body to Byte[], because Body is an 'object'.
2) Or, you can do an equivalent of that, but without referencing the Opc.Ua.Core assembly, using .NET reflection: locate the "Body" property getter on the received value, and invoke it.
( A third option, for VB users only: It will probably work, with late binding, by simply accessing .Body property, because VB is not strong-typed as C#).
Last edit: 22 Dec 2016 15:00 by support.
The following user(s) said Thank You: hcvoort
22 Dec 2016 14:48 #4702 by hcvoort
Replied by hcvoort on topic Opc Ua ExtensionObject
Ok, I understand how I can use bitconverter. But from the EasyUAClient.read(endpoint, node, AttributeID=13) I get an extension object with a Byte[10] in there somewhere. How do I get it to a 'real' Byte[]? Then I can decode it. I hope you understand my explanation.
BR,
Carsten Voort
22 Dec 2016 14:27 #4701 by support
OK, then the 10 bytes are 4 bytes for each of the Float fields, and 2 bytes for the Int16 field.
According to OPC UA spec Part 6,
All floating point values shall be encoded with the appropriate X200 : ITU-T X.200 – Open
Systems Interconnection – Basic Reference Model
www.itu.int/rec/T-REC-X.200-199407-I/en
and
All integer types shall be encoded as little endian values where the least significant byte
appears first in the stream.
With .NET class BitConverter ( msdn.microsoft.com/en-us/library/system.bitconverter(v=vs.110).aspx ) and methods like ToSingle() and ToInt16(), it shouldn't be too difficult to decode it.
22 Dec 2016 14:14 #4700 by hcvoort
<opc:StructuredType Name="Zeef">
<opc:Field Name="Max_Spanmaat" TypeName="opc:Float"/>
<opc:Field Name="Min_Spanmaat" TypeName="opc:Float"/>
<opc:Field Name="ZeefType" TypeName="opc:Int16"/>
</opc:StructuredType>
22 Dec 2016 13:52 #4699 by support
Please post the XML description here.
22 Dec 2016 13:37 #4698 by hcvoort
Dear support,
I know the xml description but I cannot do anything with the Byte[10]. Since it is an extension object there is no way to cast it or extract any bytes using normal system methods. Does QuickOPC provide such methods?
BR,
Carsten Voort
22 Dec 2016 12:13 #4694 by hcvoort
Oke, I will dig into it.
BR,
Carsten Voort
22 Dec 2016 12:12 #4693 by support
You will need to read in, or otherwise obtain from the server side, the actual XML that described the data type. Having that, use OPC UA Spec Part 3 Annex 3, and Part 6 Mappings, to decode.
22 Dec 2016 12:06 #4692 by hcvoort
Oke, let's say that I receive this Extension object with Byte[10] as a value and I know that the structure at the PLC side is defined as follows:
STRUCT
ZeefType : INT; //2 bytes
Min_Spanmaat : REAL; //4 bytes
Max_Spanmaat : REAL; //4 bytes
END_STRUCT
which makes a total of 10 bytes. How can I decode the Byte[10]? Which methods do I use? Could you provide me with a few lines of (pseudo) code?
BR,
Carsten Voort
22 Dec 2016 11:54 #4691 by support
I should add one more things: If you only have one, or a handful of data types you need to deal with, and you need them upfront (i.e. you are connecting to an OPC server/configuration that you know), the recommended steps can be made much easier (and you wouldn't even need the extra assemblies).
Let's say you are dealing with one custom data type, which is represented by 10 bytes inside the ExtensionObject. As part of you development (i.e. not directly in the program you are writing), you can read the DataType and determine the DataTypeDescription using my hints - but just once, manually. You will end up with an XML fragment that describes the fields of the custom data type. You will then write a custom decoding algorithm (into the actual project you are developing) that would take these 10 bytes and interpret them accordingly to the data type description - that should be just couple of lines of code. If you have just one data type or a handful of them, this approach is *much* simpler than trying to write a generic solution, which is what I assumed in my hints.
