Live Binding step by step
01 Dec 2016 12:06 #4613 by support
Replied by support on topic Live Binding step by step
1. If you use the "Bind to Point" command repeatedly, it should start on the (server and) node you have selected last, making it easy to work with nodes that are located "nearby" in the address space. Does this work? Or maybe you are using a different sequence of steps - please describe your precise steps then.
2. Please provide the text of the error message for the timeout. There are multiple possible timeouts, and each is configured differently. This said, however, you can modify them from the code for the workings of your application, but it won't be possible to modify them for the Design mode inside Visual Studio.
29 Nov 2016 18:02 #4609 by support
Sent: Tuesday, November 29, 2016 10:35 AM
Thank you very much it works. Each times i need to insert my remote opc server in dialog box for each items. It possible to have opc.tcp://localhost:49320 as default? It possible to add timeout when search items in opc ua? I have slow vpn so go always in timeout.
I m testing opc ua live binding
Br A.
On Nov 25, 2016 5:56 PM, "Zbynek Zahradnik" ... wrote:
Basic step by step instructions are in the Getting Started document, www.opclabs.com/files/documents/QuickOpc/Latest/Getting%20Started-QuickOPC.pdf .
Additional information is in the Live Binding section in the Concepts document, www.opclabs.com/files/documents/QuickOpc/Latest/Concepts-QuickOPC.pdf .
Both documents are also installed with the product.
Zbynek Zahradnik
Sent: Friday, November 25, 2016 10:02 AM
Ok now i test in vs 2012 ultimate. I want use livebinding but seem that missing some components can you explain me step by step how use livebinding?
Br A.
