Upgrade QuickOPC-UA without uninstalling the current one
21 Oct 2016 04:34 #4495 by support
The uninstallation of the product does not uninstall the license.
For upgrade from version 5.35 to 5.36, it is recommended to simply install version 5.36 "over" existing version 5.35. They will share the same installation folder etc.
You will need to rebuild your projects with the new QuickOPC assemblies.
NB: Parts of this answer assume that you are using the .NET components and not the COM components.
The following user(s) said Thank You: andis59
20 Oct 2016 17:35 #4494 by andis59
Is it possible/recommended to just install a new version of QuickOPC-UA .NET without uninstalling the current installation?
We are running version 5.35.414.1 and want to upgrade to 5.35.1173.1
If we uninstall 5.35.414.1 will the license be uninstalled also?
