(Array)e.Vtq.Value = NULL
27 Sep 2016 13:29 #4390 by support
Replied by support on topic (Array)e.Vtq.Value = NULL
Is it really e.Vtq.Value that is null, or is it actually already the e.Vtq that is null?.
If e.Vtq is null: In this case, e.Exception is not null, and contains the exception object that describes the problem. Please examine this exception object (e.g., its Message property), to obtain further details.
If e.Vtq is non-null but e.Vtq is null: In this case, most commonly it is a "bad quality" data being delivered by the OPC server. Please examine e.Vtq.Quality. If it is a Bad quality, then there is no usable Value to speak of, and that's why it is null. In this case, we are delivering you the Vtq as it was sent to us by the server. You would therefore need to investigate on the server side for the cause of the Bad quality.
Mfg
Zbynek Zahradnik
27 Sep 2016 11:57 #4388 by tmouslih
Sehr geehrte Damen und Herren,
Wir haben das Problem dass wir ab und zu nach einem Event ItemChanged von einem Char-Array, ein NULL-Wert((Array)e.Vtq.Value) bekommen.
Unter welchem Umständen kann das auftreten?
Ich würde Ihnen sehr dankbar wenn Sie meine Frage umgehend beantworten könnten.
Vielen dank im Voraus
Time to create page: 0.172 seconds
