Live binding [to a listview]
06 Sep 2016 06:18 #4325 by support
In this case I would recommend to go the "standard" way, and fill the ListView in the event handler.
There are two reasons for that: 1) If you just wanted one column, it would be doable when picking just piece from the incoming data (such as the value, or Vtq) - but becomes much harder to combine it with tag name etc., 2) it isn't doable with Live Binding and multiple columns (sub-items).
06 Sep 2016 06:13 #4324 by support
Sent: Monday, September 05, 2016 11:17 PM
To: Z.
Subject: OPC Labs Contact Form - Live binding
Hi
Can you databind to a listview and show tag name,value,quality and time stamp ? Or is better to use the data hangs event in this scenario ?
N.
