Unable to reference COM
27 Jul 2016 08:57 #4271 by support
Replied by support on topic Unable to reference COM
Trying to resolve this error is somewhat pointless, because you should not be doing it like this in the first place.
In an unmanaged C++ project, you do not add references to the project itself. You just use #import directives.
In a managed C++ project, right-click on it in the Visual Studio Solution Explorer, select Common Properties -> Framework and References, press "Add New Reference", and select the assemblies (which one is which is described in the Concepts doc).
27 Jul 2016 08:35 #4269 by olab
Replied by olab on topic Unable to reference COM
SOLVED
27 Jul 2016 07:46 #4268 by olab
Unable to reference COM was created by olab
I'm trying to reference to the OPCLabs COMObject in C++ but keep getting an error:
Error HRESULT E_FAIL has been returned from a call to a COM component.
Can you please tell me what's wrong?
