Memory consumption
08 Jul 2016 07:59 #4216 by support
Replied by support on topic Memory consumption
OK that's good to know. The programmer was just about to start working on that, so many thanks for letting me know in time.
It is weird that an antivirus could be responsible for something like that, but one never knows...
08 Jul 2016 07:51 #4215 by chrisachern
Replied by chrisachern on topic Memory consumption
i think i found the error. It was not an opc fault. There was a trend Micro Client antivirus installed. One of the trend Micro Services seemed to block the garbage Collection. The Service also needed 2 gb of ram. so i restarted the Service and after that my opc Service is performing normal.
Sorry for the Trouble.
Best Regard,
Chris
07 Jul 2016 07:34 - 07 Jul 2016 07:38 #4206 by chrisachern
I read only 3 opc items. they all have the "item canonical data type" smallint.
I added a pic with some opc Server Details.
Last edit: 07 Jul 2016 07:38 by chrisachern.
07 Jul 2016 07:00 #4205 by support
Thank you. We will attempt to reproduce the issue here.
One more question: What data type are your items? Are they integers, floats, or also strings and other more complex types?
The following user(s) said Thank You: chrisachern
07 Jul 2016 06:54 #4204 by chrisachern
Hi. Here are my assemblies included in the Project. They have all Version 5.40.251.1
OpcLabs.BaseLib.dll
App_Web_OpcLabs.EasyOpcClassicRaw.x86.dll
App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll
OpcLabs.EasyOpcClassic.dll
OpcLabs.EasyOpcClassicInternal.dll
Best Regards,
Chris
06 Jul 2016 18:15 #4203 by support
OK, thank you. This means that the GC is being called regularly.
Which version and build of QuickOPC are you using? Hint: In File Explorer, right-click on one of the "OpcLabs.*" assemblies, select Properties, and take the info from the Details tab.
06 Jul 2016 13:21 #4200 by chrisachern
i started perfmon with these 3 Counters.
Gen 0 Collections: Average increases approximately 0.03 per second -> last increases approximately 1 per 30 seconds
Gen 1 Collections: increases 1 every 3-4 minutes
Gen 2 Collections: no changes
06 Jul 2016 12:02 #4199 by support
I had a quick look at your code and I do not see anything wrong.
There is a possibility, however, that there is nothing wrong with the increasing memory consumption either. Running this service requires continuous creation of objects, and .NET only disposes of the memory when it runs the garbage collector. It would be OK for the memory to grow if the garbage collector has not run. I agree it would be somewhat strange that it did not run for 2 days or so, but it is something that needs to be clear first.
Please run PERFMON together with your process, and add following Counters for the instance of your process:
.NET CLR Memory -> # Gen 0 Collections
.NET CLR Memory -> # Gen 1 Collections
.NET CLR Memory -> # Gen 2 Collections
Let it run, and observe whether the counters increase and how often.
06 Jul 2016 10:46 #4197 by chrisachern
i have a very simple Service, which writes values of opc items to a database. My Problem is, that the Memory consumption is slowly increasing. When i start the Service, it uses about 20mb, after 2 days it's already at 180mb Memory consumption. I attached the Project. Perhaps someone can take a look at the Project.
Best Regards,
Chris
Time to create page: 0.701 seconds
