How to trust the server
07 Jun 2016 17:41 - 07 Jun 2016 17:42 #4100 by giles
Replied by giles on topic How to trust the server
I'm connectiong to a kepware server - so I exported server instance certificate and put it in c:\program data\opc foundation\ua applications\certs
no client certificates are automatically imported into kepware - and even if I import manually I still get
PC-UA service result - BadSecureChannelClosed.\r\n---- SERVICE RESULT ----\r\nStatusCode: {BadSecureChannelClosed} = 0x80860000 (2156265472)\r\n
\r\nStatusCode: {BadSecureChannelClosed} = 0x80860000 (2156265472)\r\n---- REMARKS ----\r\nThe server may have rejected the connection because it does not trust the client (e.g. certificate problem); check the diagnostics on the server side, if possible.\r\nA possible cause of this error could also be that the OPC-UA server is not running, or that it has rejected the connection due to security reasons.\r\n"
Last edit: 07 Jun 2016 17:42 by giles. Reason: spelling
07 Jun 2016 17:38 - 07 Jun 2016 17:45 #4099 by giles
1.35 -- edited - sorry 5.35!
Last edit: 07 Jun 2016 17:45 by giles.
07 Jun 2016 17:37 #4098 by support
Replied by support on topic How to trust the server
Which version of QuickOPC are you using please?
07 Jun 2016 17:07 #4097 by giles
Looking here but info seems to be out of date??
www.opclabs.com/forum/ua-connections/761-certificate-not-trusted
I can see no EasyUAClient.EngineParameters.TrustedPeersCertificateStore. and putting a certificate in C:\ProgramData\OPC Foundation\CertificateStores\UA Applications\certs does not seem to work :(
07 Jun 2016 16:28 - 07 Jun 2016 16:32 #4096 by giles
How do I get a client running opc labs software to trust an opc server? not sure where I place or import the server certificate....
Last edit: 07 Jun 2016 16:32 by giles. Reason: traust = tust
