Specify namespace, how?
02 Jun 2016 09:33 #4077 by support
Replied by support on topic Specify namespace, how?
You have already specified a namespace in your NodeId; it is the "ns=6" part of it. Are you saying that it does not work somehow? If so, what are the symptoms of the problem?
Note that this is a namespace specified by an index, which is not recommended because the server is entitled to change the indexes between sessions; ideally, you should specify the namespace by its URI ("nsu=..."). For discussion of these topics, see e.g. our Concepts document (comes with the product installation, or: www.opclabs.com/resources/documentation ) - refer to the chapter titled "Identifying information in OPC-UA", subchapter "Node IDs"
02 Jun 2016 08:26 #4076 by p.kuyper@selmers.com
Can someone tell me how to create a valid value for the namespace? See attached image.
Many thanks in advance,
Cheers,
Peter
