Could not create a certificate via a proxy: Input file was not processed properly.
17 Mar 2016 09:59 #3935 by support
Dear Sir,
I could not find anywhere in your posts an indication that you are using our product (QuickOPC).
If you are using it, please clarify how and what do you think it does not work as expected.
If you are not using QuickOPC, then you need to look for help somewhere else (possibly with the vendor of the products you are dealing with).
17 Mar 2016 09:27 #3934 by david.weiss
i have installed "InstallOpcUaNetToolkit1.30.3".
If i try to start "Softing OPC UA Client" i got the following Information-Message:
Before you can use the softing OPC UA Client an application instance certificate which will identify this installation must be created. A certificate with the following information will be generated: Application Uri: urn:NTB119:SoftingOPCUAClient Subject Name: Softing OPC UA Client Key Size: 1024 Bits Validity: 600 months
After clicking on "OK" i got the following Error-Message:
The Files "Opc.Ua.CertificateGenerator.exe", "Opc.Ua.DiscoveryServer.exe" and "REDIST.TXT" is located in the following directories:
"C:\Program Files\Common Files\OPC Foundation\UA\v1.0\Bin" "C:\Program Files\Common Files\OPC Foundation\UA\v1.0\LDS\Bin" "C:\Program Files\Common Files\OPC Foundation\UA\v1.1\Bin" "C:\Program Files\Common Files\OPC Foundation\UA\v1.1\LDS\Bin" "C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\Bin" "C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\LDS\Bin" "C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.1\Bin" "C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.1\LDS\Bin"
If i try to start "Softing OPC UA .NET Demo Server" i got the Error-Message:
Load Application confoguration EXCEPTION (FileNotFoundException) Could not find file 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Softing\OpcUaNetDemoServer\Softing.Opc.Ua.DemoServer.Config.xml'. STACK TRACE at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at System.IO.FileInfo.Open(FileMode mode, FileAccess access) at Softing.Opc.Ua.Sdk.ApplicationConfiguration.Load(FileInfo file, ApplicationType applicationType, Type systemType, Boolean applyTraceSettings) at Softing.Opc.Ua.Sdk.Configuration.ApplicationInstance.LoadAppConfig(Boolean silent, String filePath, ApplicationType applicationType, Type configurationType, Boolean applyTraceSettings)
After clicking on "close" i got the Error-Message:
UA Demo Server EXCEPTION (ServiceResultException) Could not load configuration file. SERVICE RESULT (BadConfigurationError) STACK TRACE at Softing.Opc.Ua.Sdk.Configuration.ApplicationInstance.LoadApplicationConfiguration(Boolean silent) at Softing.Opc.Ua.Sdk.Sample.Program.Main()
Can you help me with this 2 Problems?
17 Mar 2016 09:25 #3933 by david.weiss
17 Mar 2016 09:12 #3932 by david.weiss
i have installed "InstallOpcUaNetToolkit1.30.3" and try to run "Softing OPC UA Client".
At the start i got the Information-Message:
"Before you can use the softing OPC UA Client an application instance certificate which will identify this installation must be created. A certificate with the following information will be generated: Application Uri: urn:NTB119:SoftingOPCUAClient Subject Name: Softing OPC UA Client Key Size: 1024 Bits Validity: 600 months"
After click at "OK" i got the Error-Message:
"Could not create a certificate via a proxy: Input file was not processed properly."
The File "Opc.Ua.DiscoveryServer.exe", "Opc.Ua.CertificateGenerator.exe" and "REDIST.TXT" is located in the follow directories:
"C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.1\LDS\Bin" "C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.1\Bin" "C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\LDS\Bin" "C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\Bin"
and
"C:\Program Files\Common Files\OPC Foundation\UA\v1.1\LDS\Bin" "C:\Program Files\Common Files\OPC Foundation\UA\v1.1\Bin" "C:\Program Files\Common Files\OPC Foundation\UA\v1.0\LDS\Bin" "C:\Program Files\Common Files\OPC Foundation\UA\v1.0\Bin"
If i try to start "Softing OPC UA .NET Demo Server" the Error-Message:
"Load Application Configuration EXCEPTION (FileNotFoundException) Could not find file 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Softing\OpcUaNetDemoServer\Softing.Opc.Ua.DemoServer.Config.xml'. StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at System.IO.FileInfo.Open(FileMode mode, FileAccess access) at Softing.Opc.Ua.Sdk.ApplicationConfiguration.Load(FileInfo file, ApplicationType applicationType, Type systemType, Boolean applyTraceSettings) at Softing.Opc.Ua.Sdk.Configuration.ApplicationInstance.LoadAppConfig(Boolean silent, String filePath, ApplicationType applicationType, Type configurationType, Boolean applyTraceSettings)"
after clicking on "close":
"EXCEPTION (ServiceResultException) Could not load configuration file. SERVICE RESULT (BadConfigurationError) at Softing.Opc.Ua.Sdk.Configuration.ApplicationInstance.LoadApplicationConfiguration(Boolean silent) at Softing.Opc.Ua.Sdk.Sample.Program.Main()"
Can you help me, to fix this errors?
