No notification for disconnect
08 Feb 2016 10:26 #3826 by support
Great.
For readers of the forum - always check .Exception in the incoming event arguments or result objects first.
The following user(s) said Thank You: giles
08 Feb 2016 10:17 #3825 by giles
Ah sorry you are right - AttibuteData was null so I was getting a silent exception in my code
08 Feb 2016 09:57 #3824 by support
In general, the answer is No. You *should* get a notification in such case.
Can you please answer following questions:
1. Which version and build of QuickOPC are you using?
2. Is the server local or remote?
3. Which protocol (opc.tcp:, http: ?)
4. What precisely do you mean by "...the server gets switched off". Is it referring to a loss of power of a remote machine? Or a force termination of the server process? Or a properly shutdown of it? Or a properly shutdown of the whole machine? Etc.
5. How long have you waited after that?
6. Do you test the .Exception of the incoming EasyUAMonitoredItemChangedEventArgs ? Can you post that piece of code here?
Thank you, and best regards
08 Feb 2016 09:37 #3823 by giles
I am connecting to a kepware server using UAMonitoredItemChangedObservable. I find I don't get notified if the server gets switched off. Is this expected.
For reference I have ended up pinging the server every 60 seconds as below I wonder if there is a better solution you could suggest ? (I realise could use one common tag for the server and channel rather than pinging each tag)
public class ItemValue { public object Value { get ; set;} public bool Good { get;set;} static public IObservable<ItemValue> UaObservable(object status, string endpoint, string node, int updateInterval, string type) { var args = new EasyUAMonitoredItemArguments( status, endpoint, node, updateInterval ); var uaClient = new EasyUAClient(); var check = (Observable.Return<long>(0).Concat(Observable.Interval( TimeSpan.FromSeconds(60))).Select(t => { try { return uaClient.Read( endpoint, node ).HasGoodStatus; } catch (Exception) { return false; } } ).Distinct()); return check.SelectMany(c => { if (!c) { return Observable.Return(new ItemValue{Good=false}); } else { IObservable<EasyUAMonitoredItemChangedEventArgs> ret = null; switch (type) { case "int": ret = UAMonitoredItemChangedObservable.Create<int>(args); break; case "bool": ret = UAMonitoredItemChangedObservable.Create<bool>(args); break; case "double": ret = UAMonitoredItemChangedObservable.Create<double>(args); break; case "float": ret = UAMonitoredItemChangedObservable.Create<Single>(args); break; default: ret = UAMonitoredItemChangedObservable.Create<string>(args); break; } return ret.Select( r => new ItemValue { Value = r.AttributeData != null ? r.AttributeData.Value : null, Good = r.AttributeData != null && r.AttributeData.StatusCode.ToString().StartsWith("Good") } ); } }); } }
