Limit of multipleWrite and Read?
17 Dec 2015 09:02 #3726 by support
We do not have such a limitation on our side. It looks like a limitation of the target OPC server.
17 Dec 2015 08:51 #3725 by stkewors
i am testing an OPC UA connection to a TP700 Touch Panel(OPC UA Server). I use the multipleWrite method to set the variables and figured out that there is a limitation at 75 elements. Could it be that the limitation is caused by the multipleWrite method or is it just the OPC UA Server that sets the limit.
I get this error message:
OPC-UA service result - BadTooManyOperations.
----SERVICE RESULT----
Status Code:{BadTooManyOperations} = 0x80100000 (2148532224)
best regards
Kevin
