Server 2008 Web Edition 32-bit
04 Nov 2015 17:59 #3642 by support
No it is not. From the 5.35 doc:
2.1 Operating Systems
The product is supported on following operating systems:
• Microsoft Windows 7 (x86 or x64) with Service Pack 1
• Microsoft Windows 8.1 (x86 or x64) with Update
• Microsoft Windows 10 (x86 or x64)
• Microsoft Windows Server 2008 R2 (x64) with Service Pack 1
• Microsoft Windows Server 2012 (x64)
• Microsoft Windows Server 2012 R2 (x64)
The edition (Web) does not matter, the problem is that it is not R2 with SP1.
In reality it would probably work on it just well. It's just that we need to limit the support choices.
The following user(s) said Thank You: cdunlap
04 Nov 2015 16:43 #3641 by cdunlap
Can you tell me if this version of Server 2008 is supported? Whenever I try to run the installer for 5.35 on it, I receive an error stating "This program does not support the version of Windows your computer is running".
I know that the Web edition is a very limited edition of the OS from Microsoft, so I would not be surprised if it is a limitation there, but I wanted to run it by you.
Thanks for the help.
