QuickOPC.NET - EasyOPCDAClient : Issue on 64 bit
25 Aug 2015 11:40 #3508 by support
Pls see the reply to the other similar posts you made.
25 Aug 2015 09:44 #3504 by s-petit@hotmail.fr
I tried EasyOPC 5.34 on Windows 7 and i had an issue. Finally, i made a simple test with the demo project "EasyOpcNetDemo.exe" and had the same issue : when i try to browse server, an unexpected exception occurs.
I tried with VS to see more in debug, the following exception occurs : 'System.Runtime.InteropServices.SEHException' at App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll
If i change target plateform of the application to x86 instead of AnyCPU or x64, the same test works.
I didn't find what was wrong, do you have any idea ?
