Develop under Windows 7, deploy on Windows Server 2008?
03 Jan 2011 09:43 #176 by support
It doesn't matter; that is, for the purpose of coding and building the application - it is common and supported scenario.
Understandably, when you deploy on a different system, the system may have different settings such as security and other configuration, and therefore the configuration steps needed to be made on that system may be different - but that's kind of obvious.
03 Jan 2011 09:40 #175 by support
[question from a reseller, translated]
If [a customer] wants to develop a system in QuickOPC.NET 5 under Win 7, but will deploy on win server 2008, should he expect some complications, or is the [type of] system irrelevant?
