Create new items from the code
30 Jun 2015 10:01 #3242 by support
OPC Data Access specification does not contain anything that would allow the clients to create new OPC items inside the server. You can only read/write/subscribe to items that the server already has.
30 Jun 2015 08:36 #3241 by pankaj
Hi, I have got a requirement where I need to create items on the runtime.
Just like using "EasyDAClient.BrowseBranches" I can browse between nodes, How can I create items from code ?
I assume there should be something like CreateItem ( and which takes Names, Address, Data Type, Client access type and Scan rate etc as parameter). I tried looking in the documentation but couldn't find any.
Time to create page: 0.957 seconds
