EsayAEClient No Events
10 Jul 2015 18:46 #3431 by support
Replied by support on topic EsayAEClient No Events
I am happy that it works now :-) And thanks for the offer.
03 Jul 2015 08:33 #3260 by Dalibor37
Replied by Dalibor37 on topic EsayAEClient No Events
Thank you very much, Im getting events. If you wiil come to Croatia on holydays Im buying bear :). Thanks once more.
02 Jul 2015 23:53 #3259 by support
Please download QuickOPC 5.34.274.1 (or later) from www.opclabs.com/products/quickopc/downloads .
Then re-install it, rebuild your project with new assemblies, and re-test.
02 Jul 2015 19:11 #3258 by Dalibor37
Thanks very much,
I will check evry 5 min for download :) you saved me.
02 Jul 2015 17:47 #3257 by support
As indicated by email, I have reproduced the problem. First diagnostic results show that the server's SetFilter(...) function is returning E_NOTIMPL, which is not really allowed for a compliant server, but we can try some workaround.
I have changed the client code so that when you do not specify a filter (i.e. there is no filtering - a "pass-through"), we will not even call the SetFilter(...) in the server.
This works well in the sense that the event with "Not implemented" is no longer generated. I cannot tell whether the final goal - i.e. receiving proper events from the server - is achieved, because the server does not appear to be generating events right now (I think this is because it is not actually configured to do anything at the moment). The are not coming to Matrikon OPC Explorer either.
The issue right now is the delivery. I have started the automated build process, which, however, takes quite a long time (hours). If that succeeds, I will post a new build as the public download, and inform you here. If this is not finished in time, I will send you a ZIP file of updated assemblies only, and notify you by email. I will then complete the full build after July 10.
02 Jul 2015 07:09 #3255 by support
I have emailed the FTP info to you now.
02 Jul 2015 07:00 #3254 by Dalibor37
Can I send you on some me mail ftp link with credentials to download vmware virtual machine. I think it will be aveilable in 1.5 hour ?
01 Jul 2015 12:40 #3252 by Dalibor37
Thanks very much!!!!!
01 Jul 2015 12:04 #3251 by support
This would be tough in terms of time available for it, but I will try to do my best.
01 Jul 2015 12:02 #3250 by Dalibor37
So i can convert it to virtual machine with VMware and send to you ? tomorow ?
