MonitoredItemChanged stop reporting data change events
12 May 2015 07:24 #3123 by adid@contel.co.il
hello,
there is also problem that MonitoredItemChanged stop reporting data change events.
you can see in the logs attached in file Info.txt in 2015-05-12 00:23:05 the last monitorItemChanged event, after this is stop reporting dataChange events although the 10 tags i listen to there dataChange events were changing.
the last dataChange event in info.txt :
2015-05-12 00:23:05 – m_EasyUAClientCoils_MonitoredItemChanged line 2406 state Coil Value 0
you can see the file opc.txt for the opcLabs logEntry.
thank you,
Adi Damty
