ClientMode.Datasource & DesiredvalueAge
18 Apr 2015 14:16 #3053 by support
Hi, here it is:
var _ReadParam = new DAReadParameters(DADataSource.ByValueAge, m_ValueAge); // Reading a single item DAVtq vtq = client.ReadItem("myServer", "myItem", _ReadParam); // Reading multiple items DAVtqResult[] resultArray = client.ReadMultipleItems(new[] { new DAReadItemArguments("myServer1", "myItem1", _ReadParam), new DAReadItemArguments("myServer2", "myItem2", _ReadParam) });
Read parameters do not apply to writing (neither did the corresponding parameters apply to Write-s in previous versions).
The following user(s) said Thank You: philgerm
18 Apr 2015 08:24 - 18 Apr 2015 14:19 #3052 by philgerm
I translate a code from 5.1 to 5.23 version.
How I use my _ReadParam variable for reading simple item, multipleitems or writing operations ?
//!! 5.1 // m_ClientOPC.ClientMode.DataSource = OpcLabs.EasyOpc.DataAccess.DADataSource.ByValueAge; // m_ClientOPC.ClientMode.DesiredValueAge = m_ValueAge; //!! 5.2 _ReadParam = new DAReadParameters(DADataSource.ByValueAge, m_ValueAge);
Thanks in advance.
Last edit: 18 Apr 2015 14:19 by support.
