VS2012 Building Issue
01 Apr 2015 09:34 #3026 by support
Replied by support on topic VS2012 Building Issue
Please uninstall the version you have, and download and install the latest from the Download area on this Web - it should identify itself as 5.33.1152.1 (or later). This should fix it.
31 Mar 2015 13:40 #3025 by support
Thank you. I was able to reproduce the problem now. You are not doing anything wrong; it appears to be a problem in the version 5.33 we have recently released.
We are working on a fix. I will post another reply here when it is ready.
I am sorry for inconvenience.
31 Mar 2015 09:26 #3024 by jamiejj
Replied by jamiejj on topic VS2012 Building Issue
1. I get the error saving and building the form and sometimes when adding uabinder.
2. The latest one from the website. Version 5.33.1134.1.
3. This is the only version I have installed.
I have tried this on 2 different PC's and got the same problem. And both are the same version.
Jamie
31 Mar 2015 08:59 #3023 by support
1. At which moment do you get the error? When trying to save the form?
2. Which QuickOPC version and build are you using? (best way to obtain this is to right-click on one of the assemblies using the Windows Explorer, and select Properties, then look at the Details tab)
3. Have you installed some other version before? (version mixup could be one of the causes)
30 Mar 2015 21:33 #3022 by jamiejj
Hi there,
I am trying to set up a simple read of a tag using uabinder and I keep getting the following error:
Code generation for property 'Binding Types' failed. Error was: 'Type 'System.ComponentModel.Component' in Assembly 'System, Version=4.0.0.0, Culture=neutral, PublickKeyToken=b77a5c561934e089' is not marked as serializable.'
I think I am missing something little, but I think I have been looking for to long and need a fresh idea!
Thanks in advance.
Cheers
Jamie
