Unable to access windows certificate store
21 Mar 2015 18:20 #2970 by support
I understand that you specify the certificate store location through code? If so, can you post the relevant piece of code here?
12 Mar 2015 15:04 #2956 by Bmello4688
I am using a certificate that is located in my local machine -> personal store(MY) to make a connection to my UA server(KEPServer).
I am getting an error on the client that says the client is unable to access the windows certificate store. The user has permission to access the certificate's private key, but it seems that the client is not able to even get to that step.
The certificate look up works fine on my machine, so I am not sure what kind of permission problem I am having.
