Opc Labs cause the Kepware to stuck
08 Mar 2015 12:55 #2948 by adid@contel.co.il
Ok,
i will contact the vendor Kepware about this.
thank you,
Adi Damty
03 Mar 2015 19:34 #2889 by support
I am sorry but unless there is some identifiable misbehavior of QuickOPC, this is a problem that should be solved with Kepware.
03 Mar 2015 16:02 #2887 by adid@contel.co.il
hello,
also attached the Kepware log file.
thank you,
Adi Damty
03 Mar 2015 15:59 #2886 by adid@contel.co.il
hello,
i run my service that use the OPCLabs and it's cause the Kepware to be stuck.
when trying to restart the Kepware i get message : Window could not stop the Kepware Runtime service at local computer. Error 1053 : The service did not response to start or control request in timely fashion.
it's occured twice.
attach Log file i was created from log entry in OPCLabs.
why does opcLabs cause Kepware to be stuck ?
thank you,
Adi Damty
