Problem with reading and writing
  • miron
03 Mar 2015 14:56 #2881 by miron
Replied by miron on topic Problem with reading and writing
In KepSerwer during loading coniguration I got information:
Simulation mode is enabled on device 'common2OpcModel.msarna'. In Simulation mode the memory map is based on client update rate(s). Refer to server help for more information.
  • miron
03 Mar 2015 14:36 #2880 by miron
The same result with:
(I have use in reading: DataSource= DADataSource.Device,
but I have problem with writing)
public static void Test2() { EasyDAClient c1 = new EasyDAClient(); EasyDAClient c2 = new EasyDAClient(); c1.Isolated = true; c2.Isolated = true; c1.WriteItemValue(new ServerDescriptor (){ ServerClass = "Kepware.KEPServerEX.V5"}, new DAItemDescriptor() { BrowsePath= "/common2OpcModel/msarna/L1/Z1/ZonesCtx/IsJigScanned"},true); var valB = c2.ReadItemValue( new ServerDescriptor (){ ServerClass = "Kepware.KEPServerEX.V5"}, new DAItemDescriptor() { BrowsePath= "/common2OpcModel/msarna/L1/Z1/ZonesCtx/IsJigScanned"}, new DAReadParameters(){ DataSource= DADataSource.Device } ); Console.WriteLine("val=" + valB.ToString()); }
  • miron
03 Mar 2015 14:21 #2879 by miron
Problem with reading and writing was created by miron
Hi, I have some problem:
public static void Test2() { EasyDAClient c1 = new EasyDAClient(); EasyDAClient c2 = new EasyDAClient(); c1.Isolated = true; c2.Isolated = true; c1.WriteItemValue("", "Kepware.KEPServerEX.V5", "common2OpcModel.msarna.L1.Z1.ZonesCtx.IsJigScanned", true); var valB = c2.ReadItemValue("", "Kepware.KEPServerEX.V5", "common2OpcModel.msarna.L1.Z1.ZonesCtx.IsJigScanned"); Console.WriteLine("val=" + valB.ToString()); }
case 1:
Isolated don't set = true.
Value is read as true, but I don't see changes in opc by opcclient.
case 2:
Isolated = true
Value is read as false, and I don't see changes in opc by opcclient.
Similar situation is in livemapping.
When I set values I could not see in opc client changes.
And when I set Isolated = true my tests don' pass.
In live mapping all my tags I have marked
[DAItem(Operations = DAItemMappingOperations.ReadAndWrite)]
[DARead(DataSource = DADataSource.Device)]
It looks now like writing is not performed.
Additional information:
* Reading and writing value by opc client is working.
* All tags are read / write.
* It is kepserwer with TCPIP/Simens driver and was marked as simulation
