The server does not support writing of quality and/or timestamp.
  • miron
17 Feb 2015 08:45 #2795 by miron
Thank you for explanation. It's working :-).
And thank you for your effort.
16 Feb 2015 19:34 #2788 by admin
Normal OPC writes only write the item's value. There is a provision in OPC Data Access 3.0 for writing combinations (value/timestamp/quality), which is what happens when they are all present in the mapping and you perform a mapping Write.
There is a Operations members to the [DAItem] attribute, which defaults to DAItemMappingOperations.All. You can exclude the Timestamp and Quality mapped mebers from writing by specifying (in the [DAItem]) that the Operations should not include writing. It is a bit mapped enum, therefore you can combine the individual operation with a '|' operator.
Note: I will answer all your questions, but due to their number, please allow for some time. I appreciate your interest, though! :-)
  • miron
16 Feb 2015 15:16 - 16 Feb 2015 15:16 #2783 by miron
I would like to use in my mapping:
[DANode(BrowsePath = "SomeValue")] [DAItem(Kind = DAItemMappingKind.Timestamp)] public DateTime TimestampSomeValue {get;set;} [DANode(BrowsePath = "SomeValue")] [DAItem(Kind = DAItemMappingKind.Quality)] public DAQuality QualitySomeValue {get;set;}
but I got error:
*** Failure -1073478650 (0xC0040406): The server does not support writing of quality and/or timestamp.
I understand that my OPCKepware Server does not support writing this values
but I would like make my mapping only for reading this value.
How I should correctly accomplish this task?
Last edit: 16 Feb 2015 15:16 by miron.
