Installing the license without using the license manager.
07 Nov 2014 14:45 #2499 by support
You should have access now.
For versions 5.3x, replace all occurrences of "5.2" in the document by "5.3".
07 Nov 2014 14:13 #2498 by Emilio
this topic appeared already several times. I've read about it, but I could not get the needed documentation.
Basically we also need to know how to install the license automatically during setup or also runtime, anyway without using the license manager.
The real problem is that we are not allowed to distribute the QuickOpc setup (it would be much easier of course) therefore we have to build our own setup including installing the runtime license.
I can enter the restricted area but I can't see the documentation abut the license. I assume that I must be somehow assigned to this document.
Thank you in advance.
Emilio
