Wild Card Subscriptions
07 Oct 2014 06:59 #2393 by support
Replied by support on topic Wild Card Subscriptions
I have explained that the way you have evaluated the speed, with ICONICS sample client, is incorrect. Any other client that shows the difference, while being tested for the right thing?
06 Oct 2014 19:47 #2390 by OndrejBlazek
Yes.
With third party tools it does seem that the entire Address Space is being browsed and much faster. See related post:
www.opclabs.com/forum/browsing/1474-browsing-the-address-space-quickly#2389
06 Oct 2014 13:41 #2386 by support
No, because OPC Data Access specification does not support such wildcard subscriptions.
Are you able to browse your address space faster with some other OPC client?
06 Oct 2014 12:57 #2384 by OndrejBlazek
We are looking for a solution to allow wild card subscription. Initially we were going to implement this by browsing the entire address space and then processing the wild card subscription against each tag in the stored address space to see if it matches or not.
This is not feasible because reading the entire address space, using OPC Labs, is extremely slow (hours for our OPC server).
As a result is there the option of using wild card subscriptions directly with the OPC Labs EasyDAClient? Something like:
SubscribeItem("127.0.0.1","ICONICS.SimulatorOPCDA.2","Station.01.*")
