Errors during install on Windows 8.1 64 Bit
29 Sep 2014 16:11 #2354 by support
Dear Sir,
Windows 8 and Windows 8.1 should work, I will check into why the Concepts document has not been updated.
I have tested a clean install on them just today and it worked correctly in this respect, but my tests were on x86 systems. I can test x64 later.
The error you are getting appears to be coming from an "embedded" installation of OPC UA components I am judging it from the line:
C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\Bin\Opc.Ua.DiscoveryServer.exe.Config line 7
This unfortunately is a part over which we have almost zero control. If you are not specifically interested in OPC Unified Architecture, choose a "custom" installation at the beginning of the setup program, and when the installation program gets to the page with list of components, scroll down and uncheck those that have "OPC UA" or "UA" in their name.
29 Sep 2014 11:01 #2353 by Dirk
Reading the Concepts documentation i see :
2.1 Operating Systems
The product is supported on following operating systems:
 Microsoft Windows XP with Service Pack 2 or later (x86)
 Microsoft Windows Vista with Service Pack 1 or later (x86 or x64)
 Microsoft Windows 7 (x86 or x64) with Service Pack 1
 Microsoft Windows Server 2003 with Service Pack 1 or later (x86 or x64)
 Microsoft Windows Server 2008 (x86 or x64)
 Microsoft Windows Server 2008 R2 (x64), optionally with Service Pack 1
On x64 platforms, QuickOPC.NET and QuickOPC-UA can run in 32-bit or 64-bit mode.
It seems this software does not run on Windows 8. True ? Or is it because i have Visual Studio 2010 and 2012 or 2013 are not installed yet ?
29 Sep 2014 10:47 - 29 Sep 2014 11:15 #2352 by Dirk
Edit : I was a bit quick posting this. After reading further it seems i need an older version for vs2010 any way...
I had Errors during install on Windows 8.1 64 Bit Belgian System. :S
Should i be worried ? How do i fix this ?
Could not load the install configuration.
Description: Could not load the install configuration.
Description: Could not parse install configuration.
--- bij Opc.Ua.Configuration.ApplicationInstance.LoadInstallConfigFromStream(Stream istrm)
--- bij Opc.Ua.Configuration.ApplicationInstance.LoadInstallConfig(String configFile)
--- bij Opc.Ua.Configuration.ApplicationInstance.ProcessCommandLine(Boolean ignoreUnknownArguments, String[] args)
>>> De type-initialisatiefunctie voor System.Runtime.Serialization.DiagnosticUtility heeft een uitzondering veroorzaakt.
--- bij System.Runtime.Serialization.XmlObjectSerializer.ReadObjectHandleExceptions(XmlReaderDelegator reader, Boolean verifyObjectName)
>>> Kan het configuratiesysteem niet initialiseren
--- bij System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey)
--- bij System.Configuration.ClientConfigurationSystem.PrepareClientConfigSystem(String sectionName)
--- bij System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection(String sectionName)
--- bij System.Configuration.ConfigurationManager.GetSection(String sectionName)
--- bij System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
--- bij System.Diagnostics.DiagnosticsConfiguration.Initialize()
--- bij System.Diagnostics.DiagnosticsConfiguration.get_Sources()
--- bij System.Diagnostics.TraceSource.Initialize()
--- bij System.Diagnostics.TraceSource.get_Listeners()
--- bij System.ServiceModel.Diagnostics.DiagnosticTrace.UnsafeRemoveDefaultTraceListener(PiiTraceSource piiTraceSource)
--- bij System.ServiceModel.Diagnostics.DiagnosticTrace.CreateTraceSource()
--- bij System.ServiceModel.Diagnostics.DiagnosticTrace..ctor(TraceSourceKind sourceType, String traceSourceName, String eventSourceName)
--- bij System.Runtime.Serialization.DiagnosticUtility.InitDiagnosticTraceImpl(TraceSourceKind sourceType, String traceSourceName)
--- bij System.Runtime.Serialization.DiagnosticUtility.InitializeTracing()
--- bij System.Runtime.Serialization.DiagnosticUtility..cctor()
>>> Niet-herkende configuratiesectie system.serviceModel (C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\Bin\Opc.Ua.DiscoveryServer.exe.Config line 7)
--- bij System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
--- bij System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
bij Opc.Ua.Discovery.Program.Main()
Last edit: 29 Sep 2014 11:15 by Dirk.
